FBL Gyro Ikon Flybarless - Transmitter setup
Erfan
Hi guys
In Ikon windows app you need to show Ikon were you're max and min sticks are at. I have done that for all servos and throttle etc...
But the castle esc also needs to know were min/max is for the throttle. So when I do the Ikon setup first and then do the Castle esc throttle calibration the numbers are different.
Going back in Ikon the castle numbers will be min 3% and max 90% in Ikon. Does that matter? That is the min max now not going to 0 and 100 (were it turns green in the ikon app).
I should add that it works on the beanch, I set the gov again after (in castle) and nothing happens when stick is at 0 (throttle curv) and my idleups work great (curv at 30, 70 and 90%). So everything seems to work besides ikon app no longer shows green at min and max for throttle...
For the throttle, that should be just fine. As long as you are hitting low and high throttle points. Sounds like you are about ready for the air!
