FBL Gyro IKon Bluetooth Connection
cml001
Hi guys... I got this Bluetooth module from HeliDirect and was intending to use it with my laptop.. Im an Apple iPhone user so no app.. But I like the computer fine just not the USB cable... Anyhow... The computer won't find the devise... Any suggestions or step by step directions?
Are you trying to find it in the computer, or through the Ikon software?
There is a config bluetooth button in the toolbar of the ikon software.
Not sure if that will help.
cml001
Yeah been try'n both... Tried the ikon config then the bluethooth.. Won't find devise.
Westy
LEGEND
perhaps you have wired your Blue tooth connections incorrectly? Or do they make one now that plugs directly into the IKON NOW?
I built mine and it works Perfect!
I am assuming you have your TX and RX fired up before you are trying to connect your BTA? Also your blue tooth is set up correctly in your PC? Does it find other BTA devices?
