  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
500 Ikon 2 Pitch
Discussion in 'Helicopters' started by superjet800, Jan 5, 2019.
< Mikado Virtual Flybar System Upgrade Software | Gaui X3 Build Issue >
  1. superjet800
    superjet800 New Member
    Sep 1, 2018
    26
    0
    1
    Gender:
    Male
    moyock
    This is On a tree 550e with a gen1 dx8 Alright so I go my handy pitch gauge and I have all my rods leveled and good i can get zero pitch and positive 12 pitch but it won’t go into negative pitch! I’m thinking it might be my pitch curve but my other flybarless helis (all made by blade) have a diagonal pitch curve and a curved throttle curve. Any help would be great and I’ve also taken a pic of my pitch curve which is the same curve for all pitch positions
  2. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    Do you have 0º of pitch at mid stick? If not, you need to set 0 at mid stick and then set your positive and negative.
  3. superjet800
    Sep 1, 2018
    26
    0
    1
    Gender:
    Male
    moyock
    Yep zero at mid stick +12 at stick full up zero at stick full down
  4. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    Hm, that's interesting. If you have a linear pitch curve, you should be able to get -12º. The fact that you can get it has me a little stumped. In cases like this, I create a new model and do the setup in the Tx again. There are times that either the Tx freaks out on a setting or I have changed something that I forgot about and it takes less time to just redo the Tx setup than it does to find the issue lol. Don't delete your current model, just create a new model and bind your Tx again and see what happens. You can write down your settings you have now to make it a little easier.
Share This Page
