Do to another evening in Anjong-ri I was not able to order all three cyclic servos that I wanted. So I ended up ordering 2 SAV-SH-0257MG servos from amianhobbies.com I then ordered 4 new tail rotor shafts from hobby-wing.com. I hope these shafts are stronger than the EXI stock shaft, if not they are way cheaper, but just watch the shipping method or they could end up being more expensive.
Now that I have started the upgrade process I cant wait till I finish it. My only fear at the moment is the issue I had with the mg90s when I installed them. I had to mod the mounting hole on the servo. The bearing blocks did not align correctly with the air frame, they were not spread apart enough. if I have this issue again I am not sure if I want to open the holes in the air frame or the servo. Either way I am not to crazy about doing it, but we do what we have to to get it to work. So buy the end of the month I should have all my new servos and redoing my setup, should be fun.
