I have the I charger 306B with their 500watt power supply and a balance board set up. My problem is figuring out the amp rate I can charge multiple batteries at. For instance I have a bunch of 6s, 5000mAh packs so is there an amp-per battery rate that you add up to get the charge rate? The battery manufacturer says we can charge these packs at up to 10 amps each.
