trainrider06
I've got a question concerning swash mix on my HK450 that I put together....well really swash mix in general.
ok this thing mind you have not had a chance to idle up on it really just hover in garage testing....
Ok back to swash mix...my original settings were
AILE -60
ELEV -60
PITCH +35
These are the settings I used on my blade SR only reversed. My question is this. Are these settings variable? And how variable?
Meaning can these be all set at 100% I have an idea that this must be careful because of maybe limits of the swash servos banging into their limits???
Is this correct?
Reason I ask is this Dog takes almost full throttle to get off the ground just in normal mode.....
My blades, swash, head is all set up at 0 at mid stick, I get about 8 degrees pitch on either side of 0. I know I probably need to tilt that more around 10 pos
5-6 negative. My pitch and throttle curves I have fiddled back and forth with going from a linear curve to running
Throttle settings at 0 45 60 80 100.......pitch curves run around close to that.....Granted I don't know what in the world it'll do if I have a chance to idle
up....well i did flick it on at 0 stick and the heli of course sped up and squatted down on the skids....but I didn't take it up because well I was in the garage.
So what I did was increase pitch to about +70 on the swash and wa La she lifted up just after half throttle like I am used to.....
So my question being am I an idiot for setting my pitch up like that or are those swash mix settings a personal preference thing....
Rodney
AILE -60
ELEV -60
PITCH +35
Is this correct?
Rodney
