EyeStation
Just found this in an updated manual for the Sukhoi-29MM. How to get 3-Mode mix out of a 2-position switch on the DX6i.
SAFE
â„¢
Technology Flight Modes
The included AR636 receiver has been programmed for operation in only this
aircraft, providing the following selectable fl ight modes. The programming in
this receiver cannot be changed by the user.
Stagility
â„¢
Mode: Switch position 0
This mode delivers agile response, with the important addition of automatic
recovery from any attitude. Release
BOTH
sticks and the aircraft returns to
upright, fl ight. Releasing only one stick will not provide automatic recovery. Use
this mode for slow fl ying and 3D maneuvers such as Harrier Rolls.
Flying at
high speed in this mode will cause oscillation.
AS3X 3D Mode: Switch position 1
This mode uses high rates and high gains to deliver extreme maneuverability
with maximum stability at low airspeeds. Use this mode for slow fl ying and 3D
maneuvers such as Hovers and Harriers. Flying at high speed in this mode will
cause oscillation.
AS3X Precision Mode: Switch position 2
This mode uses low rates and low gains to deliver precise response at high
airspeeds. Use this mode to trim the aircraft and fl y fast precision maneuvers.
Transmitter Setup
If using any DSM2/DSMX transmitter, the radio will have to be configured
correctly for the SAFE system to work properly.
• SAFE Flight mode is selected using Channel 5 signal (high, middle, low)
• Panic mode is selected with Channel 6 signal (high, low)
*Refer to your transmitter’s manual for more information about transmitter
setup.
IMPORTANT:
A transmitter with a 2-position channel 5 switch will only allow
the use of position 0 or position 2 fl ight modes.
DX6i 3 flight modes setup
DX6i
1. Go to the SETUP LIST MENU
2. Set MODELTYPE: ACRO
3. Set REVERSE: Gear Channel
4. Go to ADJUST LIST MENU
5. Set TRAVEL ADJ: Gear/Fmode (0) (up)100%; Gear/Fmode (1) (dn)40%
6. Set FLAPS: Norm (up)100; LAND (dn)100
7. Set MIX 1: ACT; Gear >Gear ACT, RATE D 0%; U + 100%, SW MIX, TRIM INH
Resulting in: The Gear and Mix switches operate the 3 SAFE modes
Gear 0; Mix 0 = Stagilityâ„¢ Mode
Gear 1; Mix 0 = AS3X 3D Mode
Gear 1; Mix 1 = AS3X Precision Mode
The Flap switch operates Panic Recovery:
Position 0=Off, Position 1=On. (not a momentary switch)
SAFE
â„¢
Stagility
â„¢
BOTH
Flying at
cause oscillation.
Transmitter Setup
setup.
IMPORTANT:
DX6i
