  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Batteries How To Determine Battery Size?
Discussion in 'Electronics' started by Franko48, Jan 2, 2020.
< Ikon2 Setup Question | New Trex500x Set Up >
  1. Franko48
    Franko48 New Member
    Dec 27, 2019
    7
    0
    1
    Gender:
    Male
    Edgewood, NM
    I am trying to order a plane from Amazon and they are good at listing the plane and what it has but they rarely ever recommend the battery size of a plane that does not come with a tx,rec,or charger. Most people I know like to use Lipo batteries but I have some new nicad and nmhi that I never used and would like to know how to determine if given the size of the motor and ESC what size battery I should be installing. Can anyone suggest a site to check our or your method of determining this? Presently a plane I am looking at has this motor and ESC size Motor: Brushless 4023/1050KV; ESC: Brushless 40A ESC. Also what does the 4023 represent?
  2. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,755
    64
    48
    Norman, Ok USA
    Unfortunately... the info you have isn't enough to say without just guessing. That info should be ( but isn't from what little I've read ) provided by either the model manufacturer as recommended battery and prop sizes or by the motor manufacturer as a recommended range of battery and/or prop sizes.
    As purely a guess in the ranges... perhaps between 2-3 cell lipo battery... but I'd have to give a wider range of props... between 9-11" ... don't take those as facts, they are just guesses.
    Motor sizes aren't really standardized.... usually when given like the one you mentioned... the 4023 is either the size of the outside can at 40mm around and 23mm deep... or it's the size of the internal stator. Typically I think most use the outer can size since it's more useful so you can judge if it'll fit within the area you plan to use it in. The later number is how many thousand ( k is short for kilo ) rotations it makes per volt .
    How many volts or amps the motor is less obvious since it can't be determined by size... it has to do with how it's wound and what gauge wire is used.
    So what I'd suggest.... first start with the right info since you aren't being given it straight up. You need to know the exact model name and do internet searches on the exact model and version if there are more than one. Then read any info you can find... I'd probably focus on forums ( such as this ) and check some advertisements also ( I doubt if they didn't list it where you are getting it from, other sites won't either but it can't hurt ). Now repeat the process with the exact make/model of motor and see if the info you find can be verified.
    Many ( if not most ) toy grade models are like this... slim to no technical information. Quality kits and/or builds will almost always give you the info you are now having to look for.
  3. rdsok
    Sep 11, 2011
    1,755
    64
    48
    Norman, Ok USA
    PS.... I missed something.
    The reason most people use LiPo's is because you get more power and capacity for the weight they are. To get the same power output and capacity with nihm or nicads adds a lot of unnecessary weight. Save those for builds that you need seperate batteries for the other electronics like the receiver and servo ( in otherwords, larger airplanes etc ).
    If you didn't order the plane... I wouldn't recommend it. Find something of a little better quality and that also provides the info you need to set it up properly.
  4. Franko48
    Franko48 New Member
    Dec 27, 2019
    7
    0
    1
    Gender:
    Male
    Edgewood, NM
    Thank you for all the good information. I really appreciate your time in trying to explain the issues.
    Frank
  5. Jamess
    Jamess New Member
    Nov 27, 2019
    6
    0
    1
    Gender:
    Male
    Los Angeles
    For me personally, I prefer lipo batteries. I have used 1s batteries and also used 7s 5000mah lipo. Compared with NIMH, it has many advantages.
Share This Page
