As I'm sure everyone knows, the members of the forum got together and chipped in for a 600 size nitro heli for Rc-Help. Well I'm sad to say that it's been about 24 weeks and I'm still finding issues with it. So many issues that I'm about ready to scrap the whole project. Below is one of them that is putting me over the edge.
The Align 600 NSP came with an OS 55HZ-H engine. Great engine from what I have heard, but there just wasn't something right about it. I couldn't put my finger on it though. Well, on the second hover, the flight after the first hover where I was chasing down vibrations, the muffler came loose, the engine leaned WAY out, RPM shot WAY up and I all but killed the piston ring. Not a big deal, hone the cyl, put a new ring in it and break the engine in again as if it were new.
Well that is all and well, but I have to get the head off first. For this, I have to put some heat to it, get it over 600º just to bust the red thread lock loose, or so I thought. So, I put the heat to it (video to come). Got the head loose, and let it cool.
Once it was cool enough to handle, I put it on my desk and we started taking it apart. Now, the first thing to take out is the sleeve. Most engines, the sleeve is a tight fit, and you need to put a towel or a zip tie in one of the ports and turn the crankshaft to push it up. Tried that, didn't move. Screw it, put a pair of pliars on the crank, broke the zip tie. That is when I noticed it.
In the picture below, you can see that the sleeve is NOT LINED UP with the pin!!! This is why the engine felt off to me, the ports are not lined up!
That's when I noticed THIS!!!
THEY USED A DAMN PAIR OF PLIARS TO REMOVE THE SLEEVE!!! You NEVER do this!!!
Here are a couple shots of the sleeve. At this point, I was thinking that MAYBE I could still salvage the engine. Hone it, put in a new ring and break it in again.
Here are some shots of all 4 ports. 3 intake, and the exhaust. As you can see, there is a pattern on them showing how far the sleeve was twisted!
This is what seals the fate of the block. The asshat put the sleeve in, didn't locate the pin to the sleeve and pushed the pin flush with the block!
Then guess what I found? Yup, he didn't locate the piston ring either! Thus causing the ring to push the locating pin into the piston!
So what happens when you don't use after run oil and over heat your engine? (it was like this before I got it!)
Yup, Crank covered in rust! Also notice the scarring on the smooth area where the bearing rides!
Here is the crank pin where the piston rod rides. No, that is not a "short & curley", it's a piece of lint off my rag lmao.
Yup, LOTS of scaring there as well. Crank is pretty much trashed!
Here is what the rear bearing looks like!
Then I started looking inside the block. The jackhole not only used pliers to remove the sleeve, but he twisted the ever loving crap out of it while doing so thus damaging the block!
IMO, this engine is a total loss. And I have not even gotten to the carb yet to tear it down.
This was my mistake for not tearing it apart when I first got it, but I didn't want to risk damaging it if it was perfectly fine. Well, I should have. No, I won't check it next time because there will never be a next time. buying used CRAP is not going ot happen again for me. New only from now on.
The moral of the story is this, don't ever force these engines together! Because this is what you will end up with. A nice $300 paper weight! It's going to look good sitting on my desk! Because that is all it's good for now.
