tomxl3
hi i just picked up the 600 gt i have a 100amp align esc that s only rated for 6s lipo and i have this motor
Spec.
Model: 3736
Turns: 3
Cells: 8s
Kv: 1330rpm/V
No load Current: 3.9A/10v
Max power: 2.7KW
Weight: 360g
Shaft diameter: 6mm
Dimensions: 44.3 x 61mm
Recomended ESC: 100A HV
what should i run for batteries and what c ratting should i go with been searching the net to see if anybody runs this settup but nothing im not sure what my normal running amps would be from this motor and if this is a good settup? any input would be apreciated
Spec.
Model: 3736
Turns: 3
Cells: 8s
Kv: 1330rpm/V
Max power: 2.7KW
Weight: 360g
Shaft diameter: 6mm
