lennyapplegreen
Banned
I have several of these choppers and have been experimenting with flybar weights.
Adding one more each side ( standard HK weights ) increases stability markedly, two more ( three each side ) makes the chopper really docile , obviously they must be set up for equal distance from the usual point.
Youi can turn them up on a lathe if you have one but be careful to get them as near exaclty the same weight.
I would recommend this for a beginner as it makes the heli much more manageable for first flights , maneouvrbility is still well acceptable and not lagging , the only downside I can see so far is that in a crash the flybar is carrying more inertia and likely to extend the damage further.
I will post a video as soon as I get round to it.
