450 Hitec 5065MG in 450 clone
rjeeves33
Hi. I'm working through the building of my 450 clone using the recommended align substitute parts. For the cyclic I am using high-tech 5065 MG. When I look at the online manual it appears the align surveys have the output shaft in the centre so I guess it wouldn't matter which way these surveys are installed. However the hitecs output shaft is offset and I wonder do you install servos so the output shaft is nearer or further away from the swash.
I have also seen distance from output shaft to be 13 mm when using the official align servos. Assuming the geometry is changing while using the hitecs what would the ideal distance from output shaft to the ball be?
Thank you
