  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Help Programming A Hobbywing Platinum Pro 50amp Speed Control
Discussion in 'Helicopters' started by Troy Radcliff, Jul 19, 2019.
< 450l Maiden Flight | Linkage Length >
  1. Troy Radcliff
    Troy Radcliff New Member
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    I need help programming my hobbywing platinum pro 50 amp esc
    I have a spektrum 6i radio. I can't seem to get the esc into program mode.
    Any help would be great thank you
  2. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    What version hobbywing is this? I'm getting ready to hit the sack so I will answer when i get up. Also, do you have the program box for it? If you don't, you definitely want to get one. They are WAY EASIER!
  3. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    I have a version 3
    No i wish i had a program box
    I really appreciate the help
  4. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    Just in case you don't have it, below is a link to the manual. On the left side at the bottom is the instructions on how to enter program mode. I can't explain it any better than the manual which is the only reason I'm pointing towards it. I would definitely invest in the program box though. I think they are $25 and they are worth every single red cent of that price for the time it saves you.
    http://www.hobbywing.com/products/enpdf/Platinum50AV3-100AV3.pdf
  5. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    Yeah i tried that with no luck.
    If anyone knows any other tricks to get it into program mode i would really appreciate it. Thanks again
  6. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    Try doing the throttle calibration first, then try getting into program mode. Turn on your Tx, set to high throttle. Take off the blades of the helicopter and plug it in. When you hear the initialization beeps (should be two in a row), lower the throttle all the way and it should initialize as normal. If that doesn't work, check your plug orientation in the receiver and make sure it is plugged in correctly. If you are getting servo movement, it should be, but could be in a different port.
  7. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    Thank you
    I can't seem to do that either
  8. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    Can you give us some pictures of your setup? Need some detailed ESC and Rx shots.
  9. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    Let me know if you want something else
    Thanks
  10. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    What is that orange wire to the left of the throttle? And is the white wire your ESC?
  11. pink_panther4u
    pink_panther4u New Member
    Nov 22, 2015
    7
    0
    1
    PA
    I got the Program Box... made all the difference!
  12. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    The orange wire is the rpm sens wire for the governor. .. not using and yes the white wire is the esc
  13. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    I think we have exhausted all options other than the program box. You are not able to communicate with the ESC for some reason and the only way that I know of is to use the box.
  14. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    A while back i called a hobby shop... i don't know where they were but he had me pull the power wire from something then power up everything then it went into program mode, but don't remember. I know it worked but don't remember how to do it
    Thanks though
  15. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    That sounds like a Castle ESC type thing. Not sure exactly how to do it though.
  16. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    And i cant seem to get the servos oriented correctly either i fell like a complete idiot
    Thanks for your help
  17. murankar
    Dec 4, 2011
    9,214
    387
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    First off make sure your trims are zeroed out on the throttle. Your throttle my appear to.be at zero but needs trimmed to zero so the esc can recognize zero throttle. And yes this is a castle thing too.
    ensure that the esc can see the full travel. Another thing to try is travel adjustment . The radio may not be seeing high throttle either. On the Dx6i I believe the throttle travel is default 100% and you may need 120%.
  18. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    Ok thanks ill try that
  19. Troy Radcliff
    Jul 19, 2019
    10
    0
    1
    Gender:
    Male
    Germany
    Didn't work
  20. murankar
    Dec 4, 2011
    9,214
    387
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    2 things either its faulty or its not seeing high throttle. My guess its not seeing high throttle.
Share This Page
