tricky1400
hi , hope you can help me again
I have just had the bearings fail in my tail drive shaft causing the whole shaft to lift up on spool up , making the small drive wheel rub onto the larger of the drive wheels .
I have fitted a new tail drive and put it all back together , but when I build the revs up the heli just spins round and round on the ground .
I have checked the rudder controls , left and right , shaft moves as it should
I have a red light on the gyro on hh
and when I flick the gyro switch on the radio the light on the gyro goes out ( rate mode )
when its spooling up the tail blades turn as they should too
I have checked the belt tension that looks ok
not really sure where to look next as the heli flew ok before I changed the tail drive , it did have some vibration but I could get it off the ground ok
anybody got any ideas where I could look ?
thanks for your help
