Head speed or the lack of it to be more precise. After a rebuild of a hk 450 I can not get enough head speed. The heli will probably lift off but I have not tried yet.
There is nothing binding, nothing is getting hot and I have tried different batteries. I strange thing ESC will only work when I plug it in twice. It will only switch the motor on the second time I plug it in. The first time all the servos and gyro work as normal
but the motor seems dead. Only when I plug it in the second time does the motor spring to life with the normal beeps. The ESC is Turnigy Trust 55amp. Very strange. I have re-soldered the motor wires
and again nothing gets hot. The ESC as work flawlessly up untill I removed it from a different heli. Any thought, suggestions would be most welcome. Cheers
