General Hardly any right cyclic and forward cyclic ???
Extensa
I have a cheap 4 channel, I have adjusted the swash plate and pitch so it hovers correctly but I don't seem to have hardly any right or forward cyclic movement, which makes me lose control of helicopter quickly when a gust of wind comes along. There is only two servo links that can be adjusted but it is flying level any ideas ? thanks, Mike. :)
Extensa
I think I have sorted the problem by making the linkage arms longer by 2 turns each, the swash is still level but extends further when the servo moves :)
Adam
You are correct by making the swash travel higher gives it more pitch and in this case also forward flight good job and keep flying
