now thats the spirit no matter how many parts it takes check the twist in your drive beltI have a Blade 200 SRX.I bought it new, crashed it first flite. Bet no ones done that before. anyway, I had to replace the tail boom and stab fin set. It as a light crash. got off the ground a bout two feet. went 20 ft. and crashed. So as I was saying. I replaced those parts then did a re-bind. Took it out to do a test flite and when I throttled it up, the tail motor revs up fast causing the chopper to spin counter clock wise. The main motor and blades react properly when engaged with throttle. Any suggestions on cause. I should have started out by say that I am new to the RC world, but I am going to learn to fly this little beast. No matter how many parts it takes! Help!
are the tail blades on backwards sounds like something is reversedNo drive belt. Independent motor.
Iam scratching my head try turning every thing off and rebindingIs there a controller for that motor. It seems to be responding weird like over reving
I apologize for summitting my question in your forum Bigwrench. It was a misunderstanding of where to ask my question. It want happen again. I see you are from Florida. I am from there as well. Orange Lake is where I hale from. Hopefully the weather is treating you nice. God bless you and yours sir.I have a AR7300BX receiver with no manual. However I have the manual for the AR7200BX. Are they the same programming procedure? Second will the 7300BX handle the Trex600 size copter?
As always thank all of you for your support.
Ray Lewis, R/Seahawks Cape Coral , Florida
If I have caused some confusion especially on my part of forum etiquette, I apologize, I truly do. I will try to act appropriately from now on.
