I have a Spektrum DX6i and a Hobby King HK4018 gyro (soon to be replaced with a Futaba GY240) in my old LMH110 (converted to electric). While practicing hovering, I noticed that yaw (both directions) at about 1/3 speed and up, is getting worse and worse. So while holding the helo and rotatating it I found the gyro to be working fine at low/idle speed, but as rpms increase the movement from the gyro decreases proportionately-no gyro input at all at 1/2 speed. The Delay is set at 50 and the Limit is 100.
Is there an adjustment in my TX program and/or in my gyro to correct this problem? I probably should mention that my ESC (it's old,name unknown) has been getting hot (only while flying). This is also going to replaced ASAP.
Thank you.
Thank you.
