Spektrum got DX6i all set up but wont start motor
hi hope someone can help i have went through tonys vid complete setup dx6i all done. But then i conacted the speed controler up again turned on dx then heli. started with the tune then i just get a constant beep beep beepand so on the rotor works forward and back side to side works and lift works what have i done lol
As i said in the other thread davie. Your low throttle point is wrong. Do the high stick throttle calibration, then if not try again with the throttle trim tab at the bottom. I'm 95% sure this is the issue.
Tink0027
I had this issue when I shifted all my servo wires and speed controller around the frame.., all servos would work except the motor.
As soon as I setup my speed controller from scratch, success!
In actual fact it scared me silly first time as I wacked up the throttle only to be caught unawares as for some reason my colours on the ESC to my motor is reversed...yellow to red and red to blue...
Anyway, hope you've sorted it.
Sent from my HTC Sensation Z710e using Tapatalk 2
