Tasajara
Well I wanted to build a FPV plane that would have a little speed but would slow down when needed.
And the STRYKER fit the bill. Buy a $20 airframe and start cutting and hacking.
First thing to do was cut the excess foam from the middle of the plane giving me more cargo space.
Next I lined the cargo area with balsa and 1/32 ply to ad some strength.
Also added the ply for my motor mount, I was not worried about the weight of the motor mount
because I would need to balance the weight of a camera on the nose.
I will be using a JustGoFly 500T 1950Kv motors with an "L" bracket.
Once I got the base of the plane laid out it was time to cut for the EzUHF RX and my 1.2Ghz VTX.
I had to test for right to left balance before cutting the holes. I tried to get the balance as close as possible
so that the plane may not drift left or right.
I made my own elevons being I don't like the ones that come with a Stryker. Not to fond of the plastic gray look.
I used regular CA hinges cut just below the hing slot so my elevon would fit flush. I also cut epp the fill in the hing slot that are pre-molded in a stryker.
