claytonbakerjr
Hello
I need some help and/or advice
I have the following FPV VRX and VTX
RC832 Receiver
TS58500 TX
It came RP-SMA with basic cheapy antennas which I got from HK along with the goggles.
So I ordered a Fat Shark LHCP set of antennas which as we know have SMA connectors.
I like the thought of LHCP so if later down the road I happen to fly with others I stand
a greater chance of not having to change channels.
So....I ordered some adapters to let them mount to the RP-SMA VRX and VTX
Now prior to this I was getting OK signal but only out to about 100 yards if that
and at that point I got the wavy lines hence why I went with better antennas.
So I attached the FS antennas with the adapters and GOODDD it sucked even worse.
I couldn't get 25 feet away and was so wavy and white snowy I just gave up.
So it seems the adapters may be a hindrance ??
Also I noticed even right in front of me as soon as I grabbed my transmitter to arm the quad
I was getting waviness while holding it. Then when I move the TX it went away.
So here is where I need help and or advice.
1: Should I get a filter and stick on it to help possible electrical interference?
2: In your opinions are the VTX and VRX a stable solution? I have read decent reviews on them prior to the purchase
and everything I have read stated they were a good set up and I have read some of the big boys use them as well.
3: Should I consider getting into an SMA setup (VTX/VRX) or purchase RP-SMA antennas? In order to get
away from the adapters I will have to either go one direction or the other.
The end result is I want to at least fly further than 100 foot and be able to see where I am going
Also should I consider experimenting with different channels? Currently I am on channel 1 (no other people are flying near me)
Attached is currently how my antennas are mounted on both goggles and quad. Cheapy set but I mounted the FS's the same.
Also to add as a question...
What should be my expectation of FPV video?
Now I do not expect crystal clear video because being an IT guy
I know that's not going to happen in most cases.
But I would hope that I should see at least 75% to 90% visual pleasure?
I have watched several YouTube video's with guys recording thru the FPV camera
itself and what I saw I liked but I am "No Where"...NO WHERE... close to that.
I just do not want to have an expectation that is not obtainable :/
ummmm so much for the picture it seems I am back to not being able to upload pics from PC.
I will add pic from phone if it will let me.
RC832 Receiver
TS58500 TX
