Setups FPV Gear
bsuvansh
hey guys i want to try out FPV with my Rc-Help Trainer the original version because that one is bigger then the present version so can anyone tell me from where to buy the eagle tree stuff i heard that it is awesome!
thanks!
Moved this into the FPV section.
Yes, the V1 is a little bigger, however it is very tail heavy. This is hte reason for the V3 version. I would highly suggest using the V3 even with teh shorter fuse unless you plan on putting a lot of weight up front. And even then, use the V2 or V3 wing as it's a little stronger.
pvolcko
Can buy eagle tree direct from them or any of their retailers. Also some deals to be had on ebay (or whatever India's equivalent is :) ). I bought a v2 pro OSD system off ebay a little while ago. Will hopefully be putting it to use in the next month. :)
