also, I just read this, if the CoG is ahead of the pivot point, it's like holding a sheet of cardboard into the wind. You (the servos) will have to work hard to keep it in the place you tell it to stay. On the flip side of that, if the CoG is behind the pivot point, it's like holding the cardboard with teh wind. Again, you are going to have to use a lot of force to keep it where you tell it to go. If it's right along the pivot point, your servos will not have to work anywhere near as hard to keep the blades where they should be. Like holding the cardboard in the center (equal amount on leading and trailing edge) so that the wind is providing the same force to each side (leading and trailing) and it's almost effortless to hold it.
But yes, there is quite a bit of difference between the two. The blades that I just ordered for the Pro V2 clone are 3G (FBL) blades. Hoping it will help the heli out a bit over the cheap $3 blades. $15 more so it better work better lmao.
