Hi Mark, I have had a fair amount of flying time with my Hex, they are sort of poles apart but the controls are similar, the APM flight controller allows a huge range of tuning adjustments like the heli but it also has an auto tune feature with regards to pitch and roll. My hex is razor sharp in this area, the main reason for this tune is because in loiter mode, (altitude is maintained using a barometer, and position hold is by the GPS) the hex is solid in holding the desired location even in gusting winds, it pretty well snarls at anything the tries to move it from its set location. It is awesome to fly, but you do need fine motor skills to fly it well, and I run 15% dual rates on aileron and elevator. I also have a lot of stick time flying aircraft.
To top it off I have a lot of hours on the Phoenix sim, I always practise with everything set at full noise 3D, this has given me fairly sound orientation skills, tail in, nose in, left and right side so I believe that I will make the correct stick move to recover from an unwanted flight orientation. I must add that I will not be trying anything but tail in for quite a while with the 450L. The reason for this, and I have mentioned in a previous post, that sim flying is great for orientation practise, but compared to the real world I believe they are poles apart. Sorry to ramble on a bit but I thought a little bit of background info will help you understand where I am at prior to my maiden lift off.
I am using 3GX V3.1, I have very low vibration and I meticulously balanced the mains and tail rotor. I did not use training gear, I did spool up on a test bench to check vibration and to double check tail rotor was working in the correct direction and compensating when the heli was rotated on its axis. I then took my heli, laptop and a couple of batteries to a small local park that is always quiet. Spool up time, the butterflies were running amok in the stomach. I use Futaba gear so the settings for pitch and throttle will be based on the stick position of 0, 25, 50, 75, and 100%.
Pitch: -3, -1, +1, +5, +9.5 degrees
Throttle: 0, 30, 55, 70, 85%
The first lift off to around a metre the heli drifted to the left and the tail dropped on the ascent and there was wag in the tail. I did manage to keep it within a reasonable radius but it was very sharp on the stick movements and it was a handful, I landed the heli shiny side up and made the following adjustments.
I plugged the heli into the laptop with the 3GX software running.
I dropped the gain on the rudder by 10%.
The tail drop on ascent was adjusted by using the collective pitch elevator precompensation, I changed this value up by 10% from 50 to 60.
It lifted off a lot better with the tail staying more horizontal on ascent but I landed again and went up another 5% higher on the precompensation value which fairly well sorted that out. Airborne again and the wag had nearly gone so while it was in flight I tweaked the RD rotary dial on the Tx a bit more to correct that problem and I managed a couple of stable hovers and landed again. I must admit it is still a little bit of a handful at the moment but it is improving, that's the best part. These helis have a heap of power and are a bit nervous to start with but I'll get it tuned right I hope.
On lift off it also had the tendency to drift left which was easily compensated for with a touch of opposite aileron, but out of curiosity I rechecked the swash plate and it was out a little, a bit low on the elevator and aileron so I adjusted the pitch down to even things up, I then went back through the DIR mode to redo the setup and checked everything else out to make sure it was good to go.
I have also set a switch to activate dual rates with -30% on the aileron and elevator which should smooth out stick movements, I also dropped the rudder delay to zero from 10% as recommended by most set up videos. I may even try lowering the head speed a tad, maybe that my soften it up a bit as well.
So that was the end of my first flight with the 450L, I flew back to work the next day, I work at an iron ore mine 1500kms from home so I have to wait another six days before I fly home for the next testing session to take place, and I can't wait.
Cheers
