Well it finally happened, all the parts from Ebay turned up and I had a chance to assemble them, the built was easy after doing so many Helicopters, then I had some issues with the setup which I didn't help by going with a 4 in 1 ESC but a couple of hours and I had it and the control unit sorted out. To be quite honest all it really took was closing the door to to my room and taking the time to read the instructions properly and logically work my way through the set-up process.
I failed to reach my original goal which was to build a Quad for under A$100, the final cost was A$116, well the low Australian exchange rate at the moment caused most of the over run, well as you can work out it is an El Cheapo, no bells & whistles. It does fly and is reasonably stable, I've only flow in the back yard so far, it will get into the open spaces tomorrow. After that I'll decide if I'm going to invest more or stay with Helicopters & Fixed wing, who knows.
Anyway if there is no video it didn't happen right, well it did happen this afternoon and here is the video.
