Features found in both versions include:
Lightweight, machined heatsink head
Big-bore carburetors best-suited for the intended use (F3C or 3D)
Best precision advanced exhaust cylinder timing (for F3C or 3D)
Newly designed combustion chambers, shaped to match the big bore carburetors and advanced exhaust cylinder timing
Lightweight, forged steel crankshaft counter weight to lower vibration for higher speeds
Improved back plate shape, to accommodate Futaba's BPS-1 RPM Sensor and increase primary pressure for greater stability
91HZ-R 3C Speed Engine Red
Achieve faster flight speeds and improved hovering stability. In order to get the greatest power from this engine, the carburetor intake bore is maximized to 11.6mm. To match the large bore intake, the cylinder exhaust timing has been advanced to 170 degrees. This all contributes to extreme horsepower with high speeds for stable hovering.
Package Included:
O.S. Speed 91 HZ-R 3C Helicopter Engine
GLOW PLUG NO.8
Instruction Manual
SPECIFICATIONS:
Stock Numbers:
OSMG1980 91HZ-R 3C Speed Red 61F
Displacement: 0.91 cu in (14.9 cc)
Bore: 1.09 in (27.7 mm)
Stroke: 0.98 in (24.8 mm)
Output: 3.6 hp @ 15500 rpm
Practical RPM Range: 2,000-16,500
Weight (w/o Muffler): 21.2 oz (603 g)
The cover plate has a cell to accept a sensor designed to install in the cover plate from Futaba GY701 / CGY750 Governor
91HZ-R 3D Speed Black
Pilots who slam the sticks will be very impressed with the 3D version. This engine develops all the high performance required for stable horsepower at any attitude. The big bore carburetor (11.2mm) is specially designed to develop stable horsepower at 70~80% throttle which is widely used in 3D flight. The matched cylinder exhaust timing has been advanced to 165 degrees.
Package Included:
O.S. Speed Tuned .91HZ-R Helicopter Engine with Pump, 61G Carb
#8 Glow Plug
Check Valve
Head Gasket 0.2mm
OS Speed Decal and English Instruction manual
SPECIFICATIONS:
Stock Numbers:
OSMG1982 91HZ-R 3D Speed Black 61G
" this are the details that i can find comparing this two engine. pretty much their the same lol
