Hi superbad: So a video on You tube where the guy found & marked center of gravity weighted each blade & if the blade marks lined up he wrapped the tap over the leading edge to the back of the lighter blade ! So that's how I did it! Guess I better change it ! Thanks for the comment !clear packing tape works best i found
don't think the electrical tape would stay on that well
Hi Tony; I saw a guy on You Tube do this & I had another set of wooden blades with My Helicopter so I thought I would balance them while waiting for My head rebuild parts ! I have a scale I bought for this on Amazon.com! One blade weighted 21.9 G left & right weighted 20.1 G Or left .79 oz right .72 oz! I weighted cut & the tape & put it on the center of gravity on the lighter blade & it came out perfect! So I guess I better do it over & use packing tape! I'm new at this so I'm learning from everyone! THANKS BOKI 1:55PM ILLINOIS TIME THE BEST!I have actually cut blade tracking tape out of vinyl. However, tracking is all I use it for. Packing tape is by far superior to electrical for balance since most blades are not off by more than a gram or so. However different colored tape can be used for a lot of different things to keep a theme going on a helicopter.
