Re: Just not feeling it...
More than likely you have to set your transmitter throttle end points.
First power up your Transmitter/radio controller. Put the throttle all the way up to full. After that plug in the heli and you will hear a couple of beeps. within a couple seconds of those beeps, drop your throttle stick all the way back down to minimum. You should then hear a couple more beeps and you should be set.
If you still are not getting any response, check to make sure the throttle hold button on your transmitter is not turned on.
You will get a much quicker response if you post this question in the ' Beginner Help" section. You will get help from everybody and not just me.
This thread was to share stories of that "Sixth Sense" or inside voice telling you something just ain't right.
