If they are going the opposite direction then all you should have to do is reverse that channel. Never had that issue before so I'm not sure if there is a way to resolve it in the software, or if you do it in the Tx. Give the Tx a shot first, and if that doesn't work, go into the channel map and select the reverse box next to the channel you want to reverse.
