That is exactly what I'm having to do. If you use heli in your Tx when you are flying a plane, your F-Mode switch will control your throttle and you will not have a working flap switch. I'm trying to figure out how to explain all of it as there are some parts that are pretty involved. Each new model you select, you will have to edit the settings then save it so you have it for later. But, it also keeps the stock model for when you just want to grab your interlink and fly with it. Its not as bad as it sounds. Takes about 5 minutes at MOST per model to adjust it to your DX8. But once its done, it's a very good flying aircraft.
