grampayeehaa
Day two was devoted to mounting the servos in to the fuse. No problems there. The long push rods went in easier than expected. Below are a few pictures. The first picture is of the replacement firewall. It came out very well and will be strong enough for the OS46. The next photo is of the front compartment. It was intend for the battery for the electric motor but will now be used for the fuel tank for the glow motor. Next is the generous radio compartment. Just below the servo tray is where the optional drop box would go. You can see Bruce on the other side of the wing half fiddling with the servo extension wires. This next photograph shows the servos in place but the point of interest is the yellow cube to the right side of the fuse. This is the devise that will assist in mechanically adjusting each servo. the last snapshot is the servos mounted in place.
