500 cyclic and tail servo issues and pitch
wolfman76
The cyclic servos aren't returning to center fast like they are suppose to they are returning slow and the tail barely moves at all also when I move the left stick to midstickthere is alot of pitch movement when the stick is moved up but hardly any when moved negative pitch. I have the Mshbrain flybarless unit but I only got everything connected but haven't went through and set it up through the software yet could this be why everything is acting the way it is?
fran11784
It's normal for the cyclic servos to move slowly back to center on the bench. Pitch range and gyro gain is programmed during setup also. Follow the setup, should be fine
wolfman76
Well I guess I must get her connected to the computer and see what happens next... just trying to work your lungs Tony. .. lol
