Sparse
So I was finally able to sit down today and start the ikon setup. With this I am using a Dx7, here are the questions I need help with.
1) My bank setup by default is on the aux channel, which I am okay with. " however " If I have both banks setup on my dx7 ( its only a two position switch ) I assume I will always be flying in one of those banks. If that's the case what happens to my idle up/ flight mode switch is it still active or disabled at that point ? I am asking because my gyro is set to gear and Tied into the flight mode switch.
2) that being my setup in the above, If I only used one bank for self level. and my gyro being on my flight mode switch. would i still have control of the tail if said switch ever needed to be activated ?
If my setup needs to be changed please let me know, I hear alot of people talking about mixing the switches and stuff. To me that's Chinese, Do to the fact I am still fairly new at the helicopter thing and the ikon. so if the setup has to be changed could one of you guys take me though the mixing part in the tx cause I do not know how to do it.
Thanks in advance
Thanks in advance
