General Could use some help
jeffweaver
Hello all iam 57 years new to rc i just bought a a b5 off road buggy kit put togather but now have to get all the elect for it sure could use some help on the esc motor combo to use i know i will be useing a lipo bat. And running on a indoor track near by just dont know what to use
Moved to the correct section.
This is a very hard question to answer. If you are going to be running at a track, I would go there and ask them what they are running. All we can do on here is give you some ideas, but more than likely, if it's like my local track, we will be way off. So ask them and see what they are using. You will need motor, pinion and spur sizes as well as shock oil, what pistons in the shocks, what toe, kick, camber and so on.
If they can't get you anywhere, we will set you up with a setup that you will more than likely have to turn down.
