Erfan
Hi guys
I got a ICE2 HV 120 on my Trex700e DFC, it's mounted in side the canopy. I don't use the governor and instead use a 85..78..85 throttle curve.
I have read that this esc needs at least 65% throttle in order to work properly, else it would get over heated. First time I found that out the hard way but managed to land safely.
But it still gets over heated and restarts when doing mild 3D after some heavy pitch/aileron/elevator stick movements (hard stops and turns).
I suspect it gets to little power and it restarts when it gets to hot. Could that be the reason?
Unfortunately I updated the esc software and forgot to reset the logs so after the last restart and crash I could not download any logs to see any temps or odd behavior.
But is my guess right? Does it need more juice, perhaps a higher curve (95..90..95) or (100..95..100)?
Perhaps it's just better to run it in governor mode instead with fixed rpm's?
The reason I have that low throttle curve is because I want to have more flight time and that works good on my t450, but I have heard that the same logic cannot be applied on 700 size heli because of the power/force needed when have pitch/aileron/elevator stick movements are applied, is that correct?
I guess moving it outside the canopy is a good idea (have done that already) and to use the governor instead with a low rpm for normal flight and some higher ones for any 3D flight?
Also just to make sure I have understood it all correctly, using the governor and having low rpm would not over heat the esc since it will always get enough juice to to what it needs to do even though the actual rpm is low, is that a correct assumption?
Best regards
/Erfan
Best regards
/Erfan
