If Tony chimes in tonight he is going to suggest ordering from the U.S. Personally I have only placed one order with HobbyKing and I was not let down, bu then again I was expecting the worst from them when I ordered. Time to the states was about a month for to Hex drivers and a backlight kit for the TH9X. When I was starting out I too looked agt HK and had everything priced out, then I found out that they did not ship to military addresses so I had to start all over and I chose Xheli.com and hobbypartz.com. I had almost the same setup but on an EXI 450 Pro.
Since Then I have upgraded all of the electronics except TX/RX which is still on the TH9X. I now run what I think is top quality electronics on a low quality heli. For now it works but I am looking at a new bird soon. You may find yourself in the same spot once you get some air time. As of right now the Align parts I am running are as follows: Main shaft, main gear, pinion gear and canopy. I have switched to Tarot for the tail output shaft (I have found these to be real durable on stiff/hard landings), you might be able to use the shaft replacement for the T-Rex 450 Sport V2. My main blades are Horizon Hobbies' Revolution 325mm C.F. for flybar.
You will find that the HK 450 requires more building than the EXI, a lot more but still not a COMPLETE build. Take your time and you will have fun building it, personally I found the build more addicting than the flying.
