lmao, yeah I forgot all about going off on that lol. The tail on this one feels very smooth and I think I just need to put some thread lock on it and it will be good. I will install the motor as one of the first things I do. Other than the belt, the build is exactly the same, you just have to remember to put a 1/4 twist to the right on the belt for proper movement of the tail.
I want to get this thing in the air so bad that I dont' want to do a video. But I know it must be done. From what I have read here, this is true.
One issue I have found on the servos is when you are mounting them to the top of the mounting bracket (on the servo it's self) you will have to trim off some material from the servo case. It has an angle that the heli won't accept. I'm a little worried this may create a weak spot in teh servo, but we will see. I did a dry fit of some of the parts last night and did find the tail boom needs to be shortened on both ends. But I will cover all of this in the video series. Should be about 6 videos long unless I do another long one lmao.
