General BNF V912 to a FlySky FS-t6
sarconastic
I posted a while ago the procedure to bind an FS-T6 to a Wltoys V911. So I assumed when I ordered a BNF V912 it would work as well. And it does, just a little different. You do not have to do the multistep procedure that the v911 requires. It is much easier.
  1. Battery in Heli and turn it on.
  2. Press and hold the bind button on the back of the transmitter and turn it on. Hold for about 3 seconds.
  3. Release button then Turn the Transmitter Off then right back on. It should Bind up.
As far as settings they are pretty basic, Just reverse Channel 2. Everything else will be pretty much the same as the V911.
****NOTE**** The one drawback to the V912 is it does NOT retain the bond settings for some reason. So you have to do this every time your turn the power to the Heli off. But after you do it a couple times it becomes old hat and only takes about 5 seconds to bind it up.
It flies a lot nicer with the FS-t6 obviously too.
Thanks
Woody
