Have you tried cleaning that servo? May be the rake style potentiometer fingers are just dirty or bent too far in after crashes or just usage... And it's causing that.
Take the canopy off, and there are 4 screws per servo that you will need to take off. Either use the electronics cleaner, or use some alcohol and a cotton swab to clean the servos. Just make sure to go lightly when you are putting it back together. The screws can strip out really easy.
