While flying my Blade nano cpx, ablade grip(with rotor blade attached) flew off. Luckily, I was able to retrive all the parts, but I can’t figure out how to re-install the blade grips. Can anyone explain the procedure for me?
The feathering shaft appears to a long skinny bolt with a nut ob the other end you will probably need to replace item "L" with a new feathering shaft Part Number BLH3313.
I truly appreciate your input and patience, but I can’t find a tool small enough to grab the tiny bolt and nut and that is small enough to work within the blade grip. Am I missing something?
I think this is the tool you need. You said something about grabbing the nut, I'm guessing you are talking about the feathering shaft? If so, since one of them broke or stripped, just replace both the feathering shaft and the bolts. There could be an issue in the metal that caused the issue.
