Please could some one point me in the wright direction with this comfusing problem (please).
I have purchased a second hand blade 400 3d and i can not see any signs of any damage or repaires it looks good to me ?
i have a dx6i radio that i braught new and fly my mcpx with, the problem is as soon as the hellie starts to lift of the ground it goes into a violent spin in one or the other direction , i have centred the slider in rate mode and removed sevo arm and centred the servo then set it all at that, i have tried different things has mentioned on tony s videos but carnt stop it from doing it .
I have just put a new set of tail blades and blade arms on because as it leaves the ground and flurts round if you back off the tail fin bends towards the tail blades and brakes the tail fin off .
I am not an experienced flyer but i can keep my mcpx in the air well sort of anyway .
I now have the feeling that the gyro may be faulty which is the e-flite gyro standard one.
the light on the gyro is always lit up in rate mode or in head lock mode not sure if this is correct ?
I have centred the tail rotor slider in rate mode and servo arm when you select head holding mode the blades tend to pull completely across to one side i am now lost with what to try next i have done it all by the book has far as i know ?
I would be very grateful for any HELP from you as i am loosin faith in it fast .
MANY THANKS JIMBO .
MANY THANKS JIMBO .
