6 flights in now I am developing a new problem, my heli flies good then does a periodic shutter. Like someone suddenly gotthe chills. Last for a couple seconds then goes away for 25 seconds then does it again. Each flight it occurs more frequently and more violently as it starting to look more like a wobble (off balance) then a quick Shriver. Any thoughts? Everything appears tight, blades are loose. Gears seem to be fine and in place with no binding. Both main gears are metal, tail is stock and good condition. Boom is tight and appears to have no damage, I can only twist the boom from a 5:45-6:15 possition. Any input will help....thanks
