Signal wire goes towards the label. To bind the 3GX to a DX8, connect your satellite Rx's to teh gyro, put the bind plug in the lower right port (bind port), and power on the helicopter. The satellites should start flashing fast. Push and hold your trainer switch on your DX8 and turn it on (making sure you are on the correct model). Once the lights on the satellite go solid, you are bound. Remove the bind plug and the gyro will initialize as usual.
