  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Binding A Dx6i
Discussion in 'Airplanes' started by BCJ, Jul 5, 2018.
< Help About Glow Engine | Best Glue To Use . . . >
  1. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
    I am trying to bind a plane to my DX6i but am having a problem.
    The bind process seems to go well but then when it's finished, after the receiver gives those three tones, there is a pause and then it starts to beep steadily. The control surfaces work, but the throttle does not. HELP !
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    That seems like the BEC is being over powered and is resetting. But you might need to calibrate your ESC. First, power on your Tx and raise the throttle all the way. Take the prop off. plug in your plane, wait for two beeps and lower the throttle stick all the way down. You should hear it initialize and you should be good to go.
  3. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
    Unfortunately, that did not work. I never got the two beeps.
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    what ESC do you have?
  5. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
    BL-20 SD
  6. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
  7. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
  8. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    Go into the travel adjust for the throttle and make the low throttle number larger. This will lower the low throttle. See if that initializes it. If that doesn't work, then I would say get a new ESC that is a little better than that one. Hobbywing comes to mind and is one that I use.
  9. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
    well, i think i might have found the problem. This is a plane i've had around for a while and the wire inside the red lead from esc to motor has come out. Can i just solder them back together.
    thanks for all your help, Tony!
  10. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    That would definitely cause the issues you are having. Not sure about the motor not working though when the other servos are working... But it is definitely worth a shot. And yes, you can solder that wire if you need to. If it is on the very end, it would be best to put new ends on the wire.
  11. Smoggie
    Smoggie Well-Known Member
    Blog Posts:
    0
    Dec 14, 2015
    2,319
    122
    73
    Aberdeen, UK
    Yes, the red wire being disconnected could cause problems but what i'm curious about is how the receiver and servos are working if the red wire from the ESC (which is the supply of power from the BEC) is not connected. The planes electronics should all be 'dead' without that wire.
    do you have some sort of separate receiver battery pack powering the receiver? If you do then the red wire from the ESC needs to be disconnected.
  12. tntpoof
    tntpoof Member
    Blog Posts:
    0
    Jan 24, 2017
    52
    3
    8
    Taylor,MI.
    get a ubec or bec leave the red wire off thats you problem..ive been in this hobby ive been in this hobby 20+ years I have always run becs .not bec off any esc
  13. BCJ
    BCJ New Member
    Blog Posts:
    0
    Jul 1, 2017
    10
    0
    1
    Gender:
    Male
    New York
    UPDATE: so after a lot of fooling around trying to solve this problem, I decided that the ESC might be shot. So I ordered a new one and just installed it. THAT was it! Everything seems to be fine now. Thanks for all your help, Tony.
  14. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    Sucks about the bad ESC, but definitely glad you got it working. :thumbsup:
Share This Page
