Re: wiring motor to esc help
I will say this, the TT, IMO, is much easier to setup after you get the gear mesh set. I mean, you can remove the tail boom and leave the tail block in the frame if you needed to just by loosening up the block and pulling the tail out. With a belt, you don't have a choice but to remove the block and separate it to remove the belt from the pulley.
TT is supposed to NOT take away as much power since there is less surface contact with the gears.
IMO, belt is MUCH more reliable, I agree that it's easier to setup (after you get it turned in the right direction lol) since all you have to do is pull on the tail until you get a bit of deflection. there is no shims or anything like that.
And a belt doesn't have the 1 or 2 bearings in the middle of the tail boom to hold the shaft straight.
And yes, the only reason we are doing this is because the OP got his original answer. But, at any time he can ask to have this cleaned up, and all of this will be deleted hahaha.
And belt vs TT is like Deans vs EC3 or what charger is best, what battery is best and so on. Everyone has an opinion.
