is the motor supposed to be plugged in during setup for some reason?? My esc is not solid lit, but blinking...I figure its because motor not plugged up....but I can set up BeastX without it plugged correct??
Yup, there is no need to have the motor plugged in while doing the setup on the Bx. And, it's also smart to do so because you are moving the throttle, adn when you exit out, it could spool up on you. So yup, your doing it right.
