I lube the bearings that I can get at every 5-10 flights. This includes top and bottom motor bearings, shaft bearings, swash bearing, small radials all over the head and tail assembly, tension pulleys, etc.
On a torque tube heli, though, there are a few that you can only get at by taking the tail apart, pulling the TT out of the boom, taking the front block out of the heli frame, etc. How often do people actually do this in practice? It's all fine and good to say it should be done every 5-10 flights, but who actually does that? I can't imagine many.
Same goes for thrust bearings in tail and main rotor holders.
What do you actually do vs recommended for these hard to reach bearings?
