ESC battery to ESC fittings?
danhampson
For my 450 i use deans connectors from the battery to the esc, are these connectors ok to use on a 6s heli. And if not which do you recommend?
I used them on all my planes and heli's, including 6s 500's and 600's. Deans is ALL I use.
Then your set to go as high as you want. I would not hesitate to use them on a 12s 600-800 setup. The higher the voltage, the less amps you will be running. watt to watt anyway.
