The bigger you go mah wise the greater the weight,
so what you gain time wise due to the increase in mah, you will probably lose due to the increase in weight, also a 25c battery is lighter than a 45c battery,
so if your only doing sport flying or learning you would be better off going for a lower c rated battery, my 25c batteries are 10 grams lighter than my 30c batteries and 15 lighter than my 33c batteries that's between 5-10% differences
