Batteries Battery Alarms
Hey
Do they make battery Alarms that can be wired inline instead of hanging off a battery?
In other words I want an alarm that I can wire directly off of the PDB.
I'm sure they do I just don't know where to get them. You could wire the one for the balance plug in line.
Tasajara
You can use this Hobby King Battery Monitor 3S wire it straight to the power leads that plugs into your battery, or where you tied all the esc power leads together. Never have to remember to plug it up again.
They sell them for 2-6s batteries.
On my setup I run a the Flip32 control board loaded with CleanFlight and you can set up a Battery alarm right off of the control board using the VBat setting. The buzzer will also serve as a lost model buzzer with the flip of a switch.
I bought 20 buzzers off of eBay for less than $6
here is a video that has the info about setting it up.
And a general Video about setup Painless360 has many helpful videos for setup and configs
Stambo
Are you going to run a board with compass and GPS?
If so the beeper needs to be as far as possible away from the compass.
